Man 1/4 throttle on a trail isn't much demand on the fuel system.
Stop wasting your time with the RK Tek crap and get the MTNTK fix kit... problem solved.
Looks like a low oil problem,you are getting a lot of lousy advice from some people..If your oil cap sticks, your motor gets no oil.A little premix won't save it.Vent your damn oil tank!!
Yes ,usually happens on only one lower crank bearing.The oil pump is trying to suck oil and getting a little.It feeds out on like 6 different lines, i would look close at lower rod bearings for heat also..
