S/C Phazer
Looking at a 07 Phazer with MPI super charger has 153 track owner says it is set up to be about 150 hp> Anybody out there have any expierence with this? Just looking for a fun little hot rod.
I bought the exact same thing about 2 months ago... I haven't got to ride it much yet but it seemed pretty good so far. horsepower is more around 140 unless it has more done to it. look into a blowoff valve from mpi. Loose the stock exhaust if it still has it. (very heavy) I rode an 02 Mountain Max 700 with triples and I think my phazer pulls just as good as the Mountain Max.
It is nice to see that it has an updated track already which should help out alot. I just finished up putting a turbo on my 08. Just keep in mind that you will have to mix race fuel in with premium at 140hp. I talked to mpi and they have a pump gas pulley, which is 6-7 pds as aposed to 11pds. Also you will still lose some hp's as you gain altittude as the supercharger cannot increase its boost the same as the turbos. The only real draw back i could see was mixxing fuel as it is hard to get race gas where i live otherwise i may have gone with the supercharger. One huge positive is that the motor is 100% stock, without a headshim so it shouldnt have lag above 6000' like the turbos. Also easier to put back to stock. If the price is right and the sled is setup then i would say go for it. The main thing that will kill the phazers are the high boost #"s and/or crappy fuel.
