Rx1 idle problems
I took the carbs off and cleaned then this weekend. I reinstalled then and now the sled will idle well. But when I give it a little throttle it won't come below 3000 rpm until I mess with the idle screw. So I lower it and it does the same thing. any ideas? Thanks
If you got them all cleaned out, guessing its not inside carbs anymore. Next step would be to synch all the carbs. You will need a carb synch tool, aka a watermanometer. That is what I would do.
