To add, remove the sway bar, remove plastic around the clutch cover, and "vent" the clutch cover with holes for cooling and belt life. I gutted both airboxes, added pods filters, and added a large vent kit. Once you ride it, you'll find it extremely easy on fuel, so use the gerry can to get down the hill and consider not filling to the brim if you won't likely need it,, every gallon (imp) is about 9#s. The sleds I ride with a nearly empty and I'll have half a tank yet,,, M7s use almost 50% more fuel on same day as the 1000,,, misc other crap like a little crazy carpet at the back where the rear exchanger was so the snow doesn't pack into a block back there. Still not sure how well it works, but I think it's an improvement. Actually I forget what all off it, just remove whatever you can,, the TSS can was 4# vrs 20# for the stock one. Also consider moving the fuel pump out from under the motor if you are ever under there, and a 15 plate chain is nice, stonger than stock 13 plate,, I run 20 over 49, but there's a 51 for the bottom I'd like to try.
