so on thursday i went down to idaho to pick up my new toy, and rt 1000 162 with 2500 miles on it and 1000 on the new motor. i knew things probably wouldnt be smooth right away as it is the way of the RT......
we get there and load the sled up after redoing the starter rope as the knot came undone other than that the thing fired right up and we loaded it into the trailer..... next day when i got home tried to start it and got it running, slapped it in reverse and sat and tried to go backwards, the belt was oily and slipping so i stopped the motor to clean the belt a little. started again no problem, but i stated it turned it to reverse and then it died like 2-3 seconds after being in reverse. did this a few times and then had to leave for work, so today i go out and just try to start the thing and see if it would run. i put 2/3 of a tank in the thing cuz i thought it had been out of gas. try hooking the battery charger to it and starting it and nothing but a tired shoulder, checked the relay by the battery, its fine.i think my battery may be bad, but it wont even run with it hooked up and charging. it starts for about 3-5 seconds and kinda drops RPM to about 1000 and sputters for a second and dies, and the slightest application of throttle will kill it instantly
took the sled into the garage, its way to hot outside right now. played with it a little, got the charger on it, got it going but this time it would rev up, got it to hang around 3500 with a little throttle and it was running strong. went to open the garage door and pull off the charger to get it some air, and maybe ride the field a little, but about 5 seconds after i took off the charger and wasnt touching the throttle, it began to lose a little rpm, so i hit the throttle and that proceded to kill it.
NOW the bottom left check engine light is on and the thing is back to turning on and running for a second and pooping out. i can hear the thing priming when i hit the RER button.... i need suggestions!!
