RSI Throttle Block & Kill Switch
B
Bristow.907
New member
I'm in need of a new throttle block and kill switch and was wondering if anyone on here has some experience with the RSI product and how it works differently from the stock polaris kill switch. Does it kill the engine the same way the stock one does or is it completely different
have been running this set up for a few years, much cleaner look, the kill switch is a momentary switch though like on dirt bike. hooks up all the same but you must hold it for 1-2 seconds for it to actually kill the engine, this way you cant bump it while riding and have the motor die on you.
Is this for the Pro? Careful if it is. A buddy did this conversion and had constant TPS problems. Best we could figure is it had something to do the wiring circuit and caused the TPS to go out of whack. He eventually replaced the TPS and went back to the stock controls.
Been running the kill switch for a couple years and it's perfect for those guys who happen to bump a normal kill switch at the most inopportune time. :face-icon-small-win
Sorry nothing for the Pro's Yet. But for the older models it gets rid of the bulky throttle block Polaris has been using forever.
We do have kits that include throttle block, kill switch, cable, and Polaris Style Heated Lever for arctic Cat M- Series Thru 2011.
Here are pics of the Cat M Kits.
Thank You,
RSI
Thinking of replacing the bars on my 07 RMK 600. It is the stock set up right now, perfect height for me, 5'5", but I am looking at replacing them, which bars do you reccomend?
That looks great. I really like the simple look. I will be picking up that set up along with new bars, risers, etc at Haydays. I am super pumped!
Sled Solutions will have our stuff at Hayday,s check them out.
SXRIAR, Best bang for buck is our $39.95 Chromoly Rise bars. Your stock bars on that I believe have about 2" of rise in them, so the 2" rise Chromoly bar is the best bang for buck. If you want to spend more you can up grade to aluminum or tapered also. You will need new grips, heaters, and glue also.
Hope this helps
Thank you,
RSI
Hope this helps
Thank you,
RSI
I just looked on your website, and do not see these bars on there, do you still carry them?
Thanks, Skylar.
