Rpm ?
SledGuru
i have a 06 900 has the complete slp performance kit in it at the start of this year i had to put a new crank in my ? is the sled is running at 7800 -7900 rpms the dealer says thats bad and should be around 7400 -7550 what is everyone out there running and should i be ok were i'm at
i have the same setup..you should be running exactly what BD stated above..
i would leave it as is, IMO
so should i had some weight so it runs around 7600 to 7800 instead of almost 8000 i have lightning weights and a blue/pink spring in it
slightly adjuating the RPM will depend on what gearing, helix you have as well..
you can try getting a slightly higher spring rate on your primary spring..i know the green/pink ha sthe same final as the blue/pink..so not sure whats just above that..
06 should have 19/42 gears, 05 should have 19/41 or 18/40 gears...
and if your running the stock helix...JUNK it..
what helix do you recommend for 05 900 at 8000 ft?
