I believe they are fairly accurate, but the digital "lags" behind actual RPM a bit. I go by the analog and shoot for 8000-8100 on a deep pull, 81-8200 on the flats....for the Powertec, not e-tec.
Still have my jump issue, pulls great down low, around 5000 lags a bit up to 6000 it jumps up to 7000 and about throws me off. Dpm checked ok, all hoses and boots seem in tact, primary spring cover updated, cushion bushing updated, threw in djs mtn ramps, plugs and wires changed. Was hoping it was a fuel issue, but I've been through 5 tanks now and it is still VERY CONSISTENT!! talked to a skidoo only mechanic and he said that was just the raves opening from mid to full and was normal... IDK what else to try but it is really annoying when following someone or leading a group and I'm throwing roost in there face or their hitting the brakes and all I'm doing is trying to hold 45-50mph...
Any new ideas?
thanks
P
08 800 154, Joe's ramps, and snow stuff can. Happens always, uphill pulls, flatland pulls, deep snow, trails. Clutch seems dry, just couldn't hold 6500 rpms if life depended on it!! Its either 55-6 or over 7. Seems pretty doggy around 55-6 as well...What sled? Any mods? How many miles on sled? Does this always happen or just under certain snow conditions? Getting snow on the belt?
All '07's need the updated spring cap/bushing assy (as in first post), and the secondary bushing in '07 are often shot at 200 miles. EVERYTHING in both clutches needs to be in good condition to be consistant.
Need help, where is the DPM soleniod on a 09 800r. My motor seems to be running rich (exessive smoke). I thought I would try to clean it first. Thanks in advance.
in straight open hill pulls i liked the 288 better, in the trees and technical riding areas the 377 hits full rpms faster, and thus works better. so for washington, i personally like the 377 better (zing zing!).
