So there are two different pistons...One set with the drop in kit, which includes the head. Another set of pistons are the direct replacement pistons??
I run a SLP Stage 3. Just wondering what would be best for me? I'm assuming just the direct replacement?
Kelsey has a drop-in kit with head +pistons. The pistons have a lower height from the wrist pin and up, effectively putting the top of the piston lower in th e cylinder. This increases port timing across the board but also lowers compression and increase squish clearance.
The head that comes in the kit is designed to make up for this by having domes sunk down into the cylinder. This would crash with stock pistons.
The replacement pistons are the same height as stock, hence will work perfectly with stock or other aftermarket head.
