We have spent a substantial amount of time and effort trying to quantify real world power gains on naturally aspirated RMKs.
Driven largely by a genuine need to find a desirable compromise to boost, its been a somewhat frustrating venture.
Many kits we tested did indeed produce results, some with impressive gains in throttle response and midrange punch but fell flat on the big end, others just making noise, however when weighed against the dollar investment, most left us feeling slighted...
Though I have no question some of these indeed perform well at other altitudes as advertised, they just didn't show well with our use demand and altitude.
Various configurations of porting, heads, pipes, silencers, pistons (even cat pistons), clutching, timing, fuels and fuel controls have all been rendered down to one true stand out.
Though I can only speak to our test results, which are all done at 9500'-13000', the RKTek Drop in kit is with a doubt the best bang for the buck...
Our testing showed the 13 kit produced impressive gains in loose snow track speed, as well as significantly better throttle response and power across the spectrum.
Though this package does require a fuel control (13 model), it is very easy to tune, it is also very easy to clutch, and is rock solid consistent.
We will be doing follow up testing with different exhausts applied to this kit soon (preliminary testing shows great promise), and also a real world evaluation of the RKTek big bore for the RMK 800 as well.
Seldom does such a reasonable investment produce such a dynamic result.
Just thought it worthy of mention as many of you have inquired about such kits...
