I don't think they are first backing out by looking at the pics, looks to me like they spin inside the hex shaft first rounding it out, then back out of the shaft. I don't think what you have done will hurt anything especially if your shaft is one of the good ones. if it's one of the bad ones, something is better than nothing IMO....Yes it is through both pieces, there are already 2 glue relief holes on opposing sides of the shaft through the aluminum. I removed the glue from those holes to make sure there was steel under it. I drilled those out to 3/16" and the other 4 sides of the shaft the exact distance. It looks like on the photos of the ones that have failed the glue is failing and the steel boss tries to back out of the aluminum, this should keep the steel boss in place.
my hope would be that they just do a recall and switch them all out like 'doo had to.I will guarantee that it will void all warranty on that shaft. Plus if the glue is faulty those rivets will not hold.
I'm not worried at all about warranty. I can buy 2 shafts cheaper than what I can drive to my dealer and back. When I drive out west it will be to ride not for warranty work.
If Poo comes out with a fix replacement you will likely be out to lunch if altered.Just sayin as the 2012 shaft may be the fix
What exactly did you guys do?
Yes it is a stock driver that was pressed on, cut down, then turned down on our lathe so we could press the steel ring on.looks like part of the stock driver cut off and pressed on the shaft for support, looks good
