Rigid led light issue!!!
J
jason leckner
Is any one running these led lights on there 14 pro's,, I have the blue light and the amber and I ran them for the first ride Sunday half wY through my ride they quit working? Any ideas
Lights
Does the generator make enough current to run an auxiliary light after it is already taxed with the grip heaters, headlight, tail light and everything else?
If you ran the LED on direct AC with no regulator/resistor you will have burned them down. I did this with a LED turn signal on a bike, if you installed front led turn signals and incandescent bulb rear turn signals it would work due to the resistance provided by the incandescent bulbs. IIRC
I have 2 rigid duallys mounted on my pro tied into the DC power and they work fine, where did you wire your lights into?
