Rider Forward Pro RMK
I know this is an old thread but anyway...
I just moved my 144 rmk post 2,75 inches forward and it is the best mod EVER for me,
I would do the same with the new Axys in a heartbeat!
I will need to hack up the hood a bit, and i will opt for a bit nicer conversion later then the dirt cheap -proof of concept (fully functional though and less then 20 bucks!!!)
The sled feels so much more snappy and agile!
Im not saying its for everyone, snappy can bite you back, but for my ridestyle its golden!
(fairly agressive tree riding, lots of WOT)
Got any pics?
As requested here's some pics!
Here's also a shopping list.
4x 90mm bolt M8 (I took whatever i could find)
4x distances 27mm (I made them from a plastic scrap block but alot of washers would do)
2x M10 ball joints
1x M10 stainless threaded rod
1x 1/4" steel plate -for the steering post stop
Its very simple, just put the post on the frontside of the pyramid! On my sled all the electrical, throttle cable and brake hose actually fits better then in the stock position!
I will have to cut the hood about 1/2" and some from the airbox (underside hood) and seal that up.
I will make new post mounts (with distances) of alu with bronze bushings as soon as my CNC mill is up and running. The Polaris plastic ones suck, they wear out in seconds and one of mine has broken in two pieces.
2x M10 ball joints
From the Pic's it looks like you have the Rush style rear over structure and the non-verticle steering post. The conversion looks like it would be a bit more complicated with the vertical post and the RMK style over structure due to the clearances and compound curves.
I do indeed have the horizontal post (144" rmk), but i think the same concept would work on the vertical style as well! (With even less hood clearance issues due to the vertical nature of the... well... vertical post:face-icon-small-hap)
But you could be totally right and i will look into this!
The benefits are however, in my opinion, worth all the effort it takes!
Getting your toes further forward on a downhill turn is a good benefit. Every inch is noticeable. A little plastic trimming and foot plate modification gets you some you may not have noticed was there.
Don't know about post forward though. I reduced bar swing to make things a little more comfortable for me.
… I reduced bar swing to make things a little more comfortable for me.
I did this also. Easy mod. Move the upper rod end inboard (towards the bushing) 1" on the mid-shaft. 45 degrees each way on the bars is 60 degrees each way at the ski. You no longer need the bar end in your crotch when making a tight turn.
Loudhandle, Geo-Can you elaborate a little more on this mod?
Tired of humping the end of my bars on tight turns lol.
LoudHandle's Steering ratio mod (pic)
I do not know how Geo accomplished his mod but this is what I cam up with.
Be aware that the bar force (input) will increase because it is no longer a one to one ratio. Roughly half again as much input force as stock (140% mathematically at least). So if you happen to be upper body strength challenged with it stock, this is not for you. FWIW
This is a poor quality file photo that I sent Dan at Alternative Impact, to support my suggestion that in the future he provide his Ti Steering parts with the optional hole for this. On the stock and ALT's current design the rod end lands in the lightening slot on the top arm of the intermediate steering shaft (Front right corner of the bulkhead).
There are two easy ways to fix this; if you are not sure you are going to like the mod I would suggest tack welding a 10mm washer top and bottom 1" in from the current hole, to prevent the rod end from sliding around in the slot.
The more permanent solution is shortening the upper arm by taking 1" out and welding it back together and placing the rod in in the original hole that is now located 1" further in. The existing rod end sits 3 1/2" from shaft center line, after the mod it will sit 2 1/2" from shaft centerline. One should also adjust the steering post steering stops to coincide with the reduced amount of turn needed to prevent any potential damage from occurring.
Hopefully that is clear enough, if not, I can take better pics. Or even offer an intermediate steering shaft exchange, as I have a few laying around as I went with ALT's TI pieces for my builds.
Looks good LH.
If you made a stepped washer for the slot to place on the underside,,, that would be the "kit".
Being anal I also dabbed some valve grinding compound under the top washer for some extra bite.
4yrs. and still tight.
I noticed little difference in steering effort but I believe that is suspention set-up anyway.
Did the post forward on the pro rmk, vertical post, today and it was almost as easy as the horizontal!
Some pics of what we butchered together, thou i would perhaps (at least) change the wood for a steel plate and the copper tube for some thick wall steel tubing but that's up to you... :face-icon-small-ton
We made the spacers for this:
20mm on the lower
35mm on the upper
It rendered in about 2 1/2-3" forward but if you file off the lower mounts you could move it less and use a smaller spacer! (or no lower spacer)
again a pretty simple and cheap mod! As expected there will be less hood clearance issues on this version, but still some cutting to do!
will also do the ratio mod later on with the addition of notching the spindles (or make new) to get more ski turn angle!
then you get the chance of turning down out of a tight sidehill situation instead of having to intentionally panel out...
I just put both the footwell forward kit and post forward kit on my 2014 PRO!! I LOVE it, and IMO it made an awesome chassis even better. Scott needs to include some instructions or answer emails if he wants to sell more of these. I was installing blindly, and I'm sure I could have shaved some serious time had there been some detailed instructions or pictures for that matter. Also, I am running the OFT pillow blocks on my post (which have to be run in the same configuration as stock), where as is would appear that DS wants you to flip the factory blocks upside down. So...I had to modify all of the DS bracketry so that I could run them in the proper configuration so that i wouldn't lose my oil lite bushings. I also need to make a plate so that my post steering stops have something to butt up against, as you solely have to rely on your spindles hitting the arms for steering stops. However, the post still wants to keep rotating!!
All around GREAT mod, but the overall kit needs some refinement and instructions. I'd hate to see a not very mechanically inclined person try and figure it all out!!
Any new news on this, I,m also looking at the post forward mod? The Pro will not hook wot aggressive bottom turns like my Mod sled with forward post, I feel I cannot get enough ski pressure to the inside ski in stock form.Also notice carving your hands are too close to your waist. Im all for moving forward..
20mm on the lower
35mm on the upper
does this forward post mod lower the bars a bit?
It actually raises the bars a bit.. not noticeable but in theory (and if you measure carefully).
If you want lower bars for, rider comfort, you would still need to change them! However since you move the center of mass you can get away with higher bars then you normally would!
Anything ever happen with these kits?
When going from one of my IQR's to my pro it always feels like the bars are in my lap and skis are way out in front of me. Like feeling like I am on top of the skis..
Looked at modding it forward myself and thought "I wish someone just made a kit" and here I am...
Would like to see some pics of the footwell mod. I have a 13 pro now and I would love to get my feet further forward. Worked great on my M sled.
Did anyone ever make a kit that would work on the AXYS or now the Matryx? And No I am not interested in a horizontal steering post.
