Rev XP Dash flickers for a second and turns off
Rev XP Dash flickers for a second and turns off, when I start the snowmobile the dash flickers for about 3-5 seconds and turns off until the machine is turned off and started again, ive checked the connector and seems fine could the dash itself be gone?
My XP had fewer electrical and electronic gremlins than my Dragon, but it had its share.
The most frequent successful fix was:
1. Identify the connector(s) to the problem area
2. Look up how to properly unlatch the connector (BRP has many latch varieties, many are not obvious)
3. Disconnect, check pins
4 Carefully and firmly reconnect.
if that doesn't work, drag out the wiring diagrams and volt-ohm meter.
