It is a good idea but did you put into consideration that it is just rod and it is just going to bend easier than the a-arm tubes. Im not saying its not going to work but i really dont see any benefits of bracing straight out on the tubes.
Actually I have done this in a pinch last year with some small angle steel on a-arms that had already broke and it worked unreal for the 2 weeks while I was waiting on new arms. No matter what if you do this right it will allow your tubing to resist bending a lot more than when it was without it. The only downsides being that it can add quite a bit of weight lol
I see what you are saying it is a good idea, but you used angle which would make it stronger, a piece of rod or flat stock wouldnt do the same as a piece of angle.
