I typically like to prime the supply line to the oil pump with oil prior to installing the oil tank with a syringe, then install the supply line to the oil tank. Then once all that is finished, I crack the 10mm bleeder screw on the oil pump to ensure the pump is primed. It is easy to get to the bleeder if you remove the can and reach from that side to access the bleeder.
