sled
also we did do 2 short tracks to and running awesome!!!!
Thanks for all the orders and reports. I am glad to hear that of the 200 plus kits on the snow we have not had a proven failure. We have had three sleds go down that had the kit. One was a Turboed 800 that had a massive detonation due to playing with numbers, The other was a stock 800 that was a cold seize the computer readout said 8000 RPM at 80 degrees. And the Third is in South Dakota and the cause is not determined for sure yet from the look of the pictures it could be coolant ingestion from a bad headgasket. I would say that we are not doing to bad. Most of the sleds out with Kits have better than 600 miles and some are above 1000 miles without failure.
We currently have Dealers in the following areas.
Baker City,OR
John Day,OR
Delta Junction,AK
Healy,AK
Eagle River,AK
Pinedale,WY
Freedom,WY
Laramie,WY
Rock Springs,WY
Idaho Falls,ID
Centerville,UT
Herreid,SD
Aberdeen,SD
Jackson,WY
Grand Praire, AB. Canada
We are currently working on more dealers.
As for the DYNO reports that everyone has been asking for The enhancement Kit has increased the Horsepower and Torque. We did not design this kit for HP it is just a side effect of an equalized system.
I will scan and post the readouts as soon as they get back from Morgan UT.
These are altitude corrected numbers. From CPI Racing.
2009 Assault 156 with a brand new engine at 100 miles on a Dynomite Clutch Dyno.
Temp HP Torque RPM
115 135.2 89.76 7948 Stock Sled
Same sled with the Enhancement Kit
Temp HP Torque RPM
145 138.1 91.66 7950 W/ Kit
On the stock run we can see a midrange drop
On the Sled with the Enhancement Kit we had no midrange drop and are above at all ranges. An Equalized system Works.
Questions and comments?
Thanks
T
Why would you dyno the stock sled at 115 degrees? Its not even warmed up to operating temp yet.
we have 7 or more kits on the snow and so far we are not seeing any det or anything with these.We are running at low elevation and high elevation. All my guys are saying its amazing how much better the sled runs!!!
We will report as soon as we have any problems. we did have sleds blowing up in 200 miles and now they are still running but i will let you know if we have any blow up with this kit!!!!!
mine actually went down with the kit but fortunatly it wasnt from the gizmo
i love that thing it makes ridnig alot more worry free and adds some torque to as well
Well that ends the story that this a fix all! Pledge800 what happened that your sled went down? I think the jury is still out on how much longer the gizmo may extend the engine jug & piston life on these sleds but what is the higher heat going to do to the engine as time goes by?
all the reviews on this kit have been absolutly excellent.. now im spending more of my time ridding my own sled and not fixing other peoples sled! cheers boys... got 650 on mine with the kit.
What were the other causes?
