so since were talking about the 600, do the efi models run better at 120 or 140? I always thought that the 120s was about right?
Just curious. Is this a similar thing to what Ski Doo use?
Also I notice the Ski Doo version is about $25. So, I was wondering if it would work on the Polaris and do the same thing as the Gizmo. It is item number 13 in the picture.
anyone use the slp bypass kit?
Was told that the slp one is not the same thing.
I am interested in where the 150* number came from? DTR puts peak performance at around 120* and most trail guys are saying that they are experiencing limp mode at 150*. I know the RMK cooling loop is a little different but I have not seen the big temp swings talked about by the Gizmo creators. I am a trail rider so it may have to do with a lack of snow packed in the tunnel? I rode in a constant 1' to 2' of fresh powder (closest thing to back country we have here in NY) on Sunday and still did not see this effect. Maybe the mountain ECU limp mode is different in account of the higher under hood temps produced?
we have 7 or more kits on the snow and so far we are not seeing any det or anything with these.We are running at low elevation and high elevation. All my guys are saying its amazing how much better the sled runs!!!
We will report as soon as we have any problems. we did have sleds blowing up in 200 miles and now they are still running but i will let you know if we have any blow up with this kit!!!!!
When you were blowing up before this kit, I would be curious to know the piston to wall clearance. I would also like to know what this clearance is now, as Polaris is starting to have dealers pay close attention to that and that alone. Most of these motors will survive 500-2K+ miles with descent clearance, or just enough to get us off warranty. As for this kit saving the 800 motor, I say NO WAY!
Not trying to knock anyone's product but you can't run these things for ever past 150 deg, they just don't like it, ask any of the respected engine builders out there. Cold shot.... The newest "hype" word in snowmobiling! Tons of paniced owners @ $300.00 a pop!
I also agree with Dub!
PaulAnd,
175 degrees are way too hot on the trail. Today after talking to carls
service dept., SLP, Dyno Tech, PMS, and Bikeman Performance they all
claim that this engine develops more solid reliable power at cooler
rpms.
Some claimed that the extra heat probably helps expand everything
enough to help improve some excessive tolerance concerns with the
pistons and the jug and for that reason alone may help make less
scoring but in the long run the excessive heat can lead to detonation!
Carls claims that if any of there big bore kits operated at 150 plus
degrees the compression life cycle would be shorter then longer since
the heat would possible cause concerns with the rings? None of the
companies I spoke with in person agreed with the higher engine temps.
All of the Dyno tests are conducted below 120 degrees for proper
cooling and to make more power with a cooler engine. I would love some
additional information from the manufacturer to explain how this heat
will save this engine to make it last longer? Besides some real Dyno
test results would be nice to offer some proof or facts.
Based on all of the feed back I got today I can say I am not ready to
try this kit at this time. My mind is still open and I would love to
hear some other feed back from some quality service depts. or dealers.
Gimmick or Gizmo?
