Recommend me...a beacon
Pebs
I was at sportmans tonight and wasn't looking for anything in particular, just killin time. I noticed a beacon in the display case for $199.99 the Pieps Freeride. Only thing I didnt like is it only has a 40 meter range. Anyways, is this sufficient? I like the price range and user friendly is a must. I dont need too many buttons to screw with when I'm trying to find a buddy under the snow. Whatre you guys all using?
Seems like everybody wants the Tracker. I am holding out for the Tracker 2 but that is kinda like the "Change" that Obama promised, it keeps getting pushed back. First October, then November and now December.:mad:
I like the Barryvox, if the guys in your group are buried, it can tell you whether they have a heart rate or not, they are simple to use. I have the Ortovox S1, It works well but they dont like to get cold? I used a digital Pieps at an Avy course last year, they are a very good unit, simple to use and accurate. I wouldn't buy a beacon that cant search for multiple victims. Good luck, tough choices. Barryvox and Pieps would be my top 2 choices. :beer;:beer;
Go to beaconreviews.com and check out what they have to say about each.
A beacon is only as good as the guy using it and the guy using it will only be proficient at using it if he practices often.
Also, if I were to guess by your post, you have not had an avalanche course. You should take one or two or....... Refresh you knowledge yearly.
BigT
My recommendation for the Pieps freeride is don't get it. The only person I would buy this beacon for is someone who I want to find, but I know won't be able to find me. (ie, a young child). The Pieps freeride works fine, but it is rather slow and cumbersome.
As mentioned above, you can't go wrong with the BCA Tracker or the Pieps DSP.
I've been very happy with my Ortovox M2's. Very easy to use, with digital meters readout and signal strength bars.
I hear straight from the horses mouth that the tracker 2 will be available in early december
I have been looking at beacons quite a bit and narrowed it down to the DSP or tracker
The DSP had me convinced but I was cought up in the multiple burial issue, apparently this happens .4 % of the time
It's nice and easy to use but the tracker searches in real time with no processing time
The DSP you turn it on to search and wait for it to do it's thing
Just bought 2 new Pieps DSP beacons from Snow Big Deal. They were great to buy from. They are a service center for Pieps as well, so when new technology comes out you can send your beacon to them and for $20 they will update the beacon software rather than having to purchase a new one! Which ever one you get make sure it a 3 antenna, the Pieps freeride is NOT!
Pieps DSP is very easy to use, a long range of 60 meters+, Three antennas, and a great mutli person burial system. I believe the tracker is only around 30meters. Also I bet the percentage of multi person burials is way higher than .4% if you only factor in the snowmobile community and not all other backcountry users.
Whats this 3 antennae business?
With a single anntenna if it is orintated 90 deg to the signal of the transmitting beacon the strength of the signal it will pick up will be much less than if it is aligned with the transmitting beacon signal. With 3 anntenna they are set 90 deg to each other so you don't get this problems as one will be more or less aligned. Easier to explain it with drawings which you can see in most avy books
