1
Just had my rear float rebuilt on my HC... BUT i also just added 40" a arms vs the stock 42" arms...
My rear shock is still sagging like it did before i rebuilt it and i used a heavier oil and still does it... not sure if its that way because my shocks are a little more VERTICLE now... OR front air pressure or what.
But this sagging is for the birds!! been trying to get my buddy to trade shocks out of his M(non snopro) but cant get him to bite the hook lol....
what a friend huh. im 215 6'3 without Gear.. and he is 165 in a wetsuit full of water...
I have seen it where the ice scraper seals (only ones visible from the outside of the shock) are tight enough that they hold air. This lets it hold some air pressure between them and the real air chamber seals on the seal head. This puts some force back on the shock to want to collapse itself. Usually this isn't a big deal because after the shock cycles a few times that pressure escapes.
Take your shock off, unscrew the air sleeve and take it off (should be able to do it by hand, but a strap wrench is required in some cases), and cycle the shock by hand. If it moves smoothly and the shaft slowly returns out on its own then the shock is ok. Clean the airsleeve and seals, check for cuts or wear, re-lube them with good suspension grease or the "float fluid" (you can get this from your cat dealer), and put it back together by hand. When you slide the airsleeve back on you will experience this little air pocket that forms between the seals I was talking about earlier. Install the shock and air it up and see what happens.
What does something like this cost?
Here is a secondary option; $750.00 gets this kit, Evol chamber installed, serviced and revalve on your rear track shock.
New Float front track replacement shocks should be in stock in a couple of weeks.
Hi Tom - is the front track float longer? If I'm reading your prior posts correctly, yes. But just wanted to confirm.
Thanks
Chewy,
Not on this kit. It is a direct replacement shock for the coil over. Will carry considerably higher finish spring rate then stock, so your bottom resistance will be greater. Valve code will be matched to this.
The complete skid we offer does have a 2.5" longer front track shock.
