I'm sure that RCS makes a Ti spring for the rear... I dont think there is much weight to be saved in the spring though.
For a spring that size you'd save about a pound - hardly worth the cost IMHO. Also you list Z Bros with Ti springs as a weight savings - not possible! They weigh 6 lbs over stock so no way will you even come close to getting those 6 lbs back with Ti springs even on all shocks! As for the stock shocks being the same as Fox air shocks - true for the heaviest Evol X but the Floats and Evol R's are lighter. The most weight savings can be had by doing the cf hood and headlight delete that you already mentioned but I have a problem with losing the venting that the stock hood has. Would be a lot better to have a cf hood with vents and those lightweight lights!
Have FUN!
G MAN
Have FUN!
G MAN
then put vents in the CF hood.... ? its not very hard.
nice name drop....
that sucks but the only way that happens if is the chain gets loose. or maybe if you held it wfo on up hill, tail landed, large jump on perfect traction snow. assuming it is a stock or close to stock motor. if your running huge hp then that is a whole other issue.
pv
if you carb it you could loose alot of weight
A Arms, Can, Timbersled skid, CF hood (FTX) with headlight delte, Floats or Zbroz with Ti springs, delete foam underhood, Skinz (SPG) lightweight seat, Ti bolts,
I think you could get it down to about 405 lbs dry for a reasonable number... but it already is an excellent machine as delivered from the factory.
IMO, the old paradigm of needing to "mod out" a sled to make it work well
Better to minimize riding weight... snow and Ice gain... tunnel side vinyl, Better Boards, de-burr/pow coat the the skid,
Stock motor. I think the chain did get loose. I thought the track was ratcheting so I kept running the sled. Polaris covered all the parts including new bearings and seals.
