OK here is what we found.....
These were taken out of the crate and set on our scale. It is a pallet scale.
09' M-8 162" Sno Pro = 487lbs
09' M-1000 162" Sno Pro = 513lbs
Like I said we took them out of the crate so there would be antifreeze in them. We weighed them first to see what they came in at before we convert them to Pro-Lite Sleds.
Mike
BDX
You get 500 Cat cash.
Mike
BDX
At the Boise snow show they had an 09 M8 153 sp on the scale and it weighed 455 with the boss seat on it. Add the 7.5lbs for the stock seat and you are at 462.5lb which I believe was the listed dry weight of that sled, crated weight will be more due to fluids added from the factory. Add 2 gal of coolant (16lb's) 1 quart of oil for chain case(1lb) 1 gal of oil in the mixing res (10lb) and 11 gal of fuel (88lb) and the total weight of the sled wet is 580.5. Without fuel the weight would be (492.5) Not bad in my view, but hey I'm coming from an 03 Poo escape
The "dry" weight means exactly that...no coolant, shock oil, DD oil, gas, motor oil, no nothing.
The "crate" weight is 479 lbs, meaning no oil or gas but all other fluids. That is the number that Cat is going off of in order to get the $500 from them. They also have a 5lb buffer zone on that to. So...if i were to drain the gallon of oil and 2 gallons of gas from my sled and it were heavier than 484lbs(479+5), then i would be eligible for the money from cat.
But with the gas and oil in there now weighing around 19.5lbs, the sled should be around 475.5lbs with no gas or oil. Which is under the "crate" weight that they are claming.
Hope that cleared things up.
