ok so when i check the resistance between the coils.....what wires am i checking i see it says yellow....so is it yellow to yellow?? and what do they mean no continuity between them
thansk
thansk
....burn it....no seriously, burn it...Ok so after rebuilding both sides of the engine.....re flashing the computer back to stock.....installing a new DET sensor....now tonight first ride after all of this....and i went for about 30 mintues...stopped at a stop sign and it shut off.....wouldnt start...waited abit...then i t fired.....it did this on and off....finally got tired of waiting towed it home....when i got home it fired right up
any ideas
how about the hex bolts on the recoil can i change them at alli hate hex bolts.....they always slip when you go to get them out and then you are in trouble...had to break one off when i took the recoil off. Also when i use the puller the stator will be inside the flywheel right.....is there anything i should watch as far as marking things for timing and so on
ok so where will i see "zero" on the flywheel then....and sorry what do you mean the mag side at TDc??
