Yes , its has been ran on a stock apex , its being installed on a turbo apex now and will be testing on the dyno soon , and yes it does automatically compensates for allitude and inlet air temp.
It is only a closed loop system when it is in the tune mode , you can set it up to be in CLC useing different setting (Low RPM , Low Boost , low throttle body openings ) So you can run leaner at low load conditions in the CLC mode and then go back to what it learned when it was ran in the tune mode. This is done so you do not burn your motor down do to a bad A/F senser .
If this system works out , it has many benifits , up to 4 or 5 D mapping auto tune ( boost , throttle body position , camshaft senser etc ) , build in knock senser that will automatically retard timing at a preset rate until knock stops , builded in data prologer , etc .
Will have more info in a couple weeks .
sounds cool but how much ? some one has a fuel injecton kit for the rx1 that includes a stand alone ecu and its around the 7500$ US mark![]()
so around the 3000$ mark? would a guy be able to use a prologger as the logger on this or have to buy a diffrent one?
I dont think any of this is practical in mountain riding.Drag racing when tenths of a second matters mabye.
Was anybody that won the big iron shoot out,big dawg or other races using RB3?Looking at it from strictly performance view.
I agree with the tracksion control , but i think all the rest is practical / related to any type of riding . When you spend $8000 to $10,000 to build a motor , $7000 to $10,000 on a turbo system and another $10,000 on lighten the sled up ( tunnel , skid , front end etc . ) and your doing all this to get better performance and then you run a engine management system that is behind the times by 10 or 20 year , this just does not make any since to me.
I for one think that after spending that kind of money , that you would want to get the most out of it with out pushing things past it limits to get it and still have some kind of safety devices / limits built in to protect your engine .
