Once the RB3 is set, you dont mess with it, I have two maps, one is for pump fuel 15#'s boost, the other is for race fuel and high boost. Baseline mapping pretty much needs to be done on the dyno unless you can borrow a good map from someone else with a similar application. I ran an entire year with no issues, after mapped the sled ran perfect all last season, the box was even sitting in the nose of my Apex, I havent heard of one fail yet.
Hey, Thanks for the replies.
AA, Due you run an A/F gauge on the Apex? If so what do you see for ratios?
and does the RB3 altitude compensate automatically?
Thanks again for the comments, I understand dynojet is comming out w/ a closed loop system starting w/ 09 cycles (PC 5), rapid bike has their RBO2, but I would think both sytems are a year away (or more) from being on a sled.
My concern is running alt from 8-13k ft. I was told by a dynojet dealer that the yamaha stock ecu compensates for alt and only one map would be needed for the PC lll, reguardless of alt. and sure you can create more maps for economy or different boost.
Does the RB3 just add to the stock ecu? If it does then I assume it will compensate. or do I need maps for different elevations?
Thanks
I do run an Air/fuel gauge, it's in the low 12's, at 20#'s boost at WOT. I have also double checked with another O2 sensor. The box does not self-compensate, only the stock fuel injection system does. I really haven't seen a need for it, always runs great. I am also running a parker knock box too.
There are some guys playing with a Closed-loop fuel injection system that automatically adjusts. It has many features, more info will be available if it turns out to be sucessful. I believe they have had it running on a stock Apex already. Would be expensive if it works out.
Yes , its has been ran on a stock apex , its being installed on a turbo apex now and will be testing on the dyno soon , and yes it does automatically compensates for allitude and inlet air temp.
It is only a closed loop system when it is in the tune mode , you can set it up to be in CLC useing different setting (Low RPM , Low Boost , low throttle body openings ) So you can run leaner at low load conditions in the CLC mode and then go back to what it learned when it was ran in the tune mode. This is done so you do not burn your motor down do to a bad A/F senser .
If this system works out , it has many benifits , up to 4 or 5 D mapping auto tune ( boost , throttle body position , camshaft senser etc ) , build in knock senser that will automatically retard timing at a preset rate until knock stops , builded in data prologer , etc .
Will have more info in a couple weeks .
OK here is what I want to do. I'm building my light weight Nytro chassis right now but I'm going to ride my RXT till I see what Yamaha comes out with for 2010. So as a result the Nytro is relegated to wife/backup sled, but i still want a little more out of it. I've got a header and muffler for it plus I'm going to do some airbox mods so it would likely benefit from new fuel and timing maps. The big clincher is I have a nitrous system that I want to slap on there so I want to do the nitrous fuel and timing with the stock injectors by instantly changing the map. I want the new maps to activate when I hit the Nos button then return to normal when I release it. Which system can do this best? I'm leaning towards the RB3 because if I turbo the Nytro I'll likely do a Powderlites kit and won't need to buy the programmer as I'd already have it.
M5
What about E&S yamaha in fort saskatchewan, they have been working w/ the RB3 and building maps. any input?
What are you looking for an RB3 map for an Apex or Nytro ?
