L
Linc
Linc, so the primary shim won't affect the secondary, because of all the float it has?
Not at all,you're shimming the side play between the spider and the movable sheave.
I took my clutch into my dealer and they shimmed it up like they did on the vector clutches.....put it on last night and its a 1000% better.....
THanks Linc for the tip.....if yours is crazy loud this is the fix....installing 20thou shims behind the pucks that hold the spider
