Radiator delete kit ?????
This could end up being a very long list.
- I have done the radiator delete (then added scratchers to keep it cool).
- Updated front plastic kit saves some weight.
- The SLP pipe and can for sure.
- FnI air intake
- I put lightweight race spindles on.
- Lightweight brake rotor
- Rider delete kit saves a little.
- You can port the track to save some weight
- I added the FnI headlight assy (ever picked up an IQ headlamp assy? - Not the lightest thing in the world).
- Removed the sway bar.
- Updated to an 07 seat assembly (less parts).
- Removed all of that plastic on the back of the tunnel.
- Will be installing a lightweight rear skid this summer.
- Finally......switched from Miller High Life to Miller High Life LIGHT (LOL).:face-icon-small-hap
09 front end supposedly 6 lbs lighter
Timbersled rear suspension 16 lbs lighter
Timbersled barkbuster front 7 lbs Lighter
Fox float 2's 2 lbs lighter
newer tracks are lighter
Ditto on the F & I headlight intake the stock one is unbelievably heavy.
Remove hood foam and replace with heat tape.
remove exhaust cover and ceramic coat the factory pipe.
