Quick Straps!
I have used them for 3 years. But what I hate, is when they fog, or you just want to pull them off for a but cause your hot. They dangle on the side, annoying when doing a lookback, and fill with snow. Im going to try the habervision fog Eliminator this year. Also, I wear glasses, so that was the reason for QS, I got the Habervision glasses inserts for the goggles. So i wont need my daily glasses. we'll see how that combo works for not fogging and being ablet o see
I just hook them upside down across the back of my helmet when not wearing them and they dont get full of snow and stay out of the way nicely.
I use them.... got about 5 goggles with the setup, change them out depending upon conditions and such. Much much better then the strap, as you can get them off your face quickly to help when over heated.
I rode along time with out the QS and I will never do it again. I strap mine around the back or make it a point to set the helmet down with the goggles underneath the helmet. Admittidley I have slacked and left em hanging on the bars and they filled with snow. I get so mad when I do that!
So far I havent had any nipple problems but it really is not nearly as nice when the slot isnt shaved up some ;)
Ya quick straps rock....Also makes it easy to pop your goggles off and put them under the hood to dry if they get soaked or whatever
Guess I'm the odd man out. I never did like them. Couldnt get them to seal up tight and didnt like the fact that it was a PITA to remove them from your helmet to thaw out or change to another pair. Eric
I'm with you. Hate the damn things. I can't get my goggles to seal on my face properly with them. Then you install the super tight so they will, and either the stupid velcro won't stap attached, or the "nipple" rips off. And yes, I installed the nipple properly. Wiped the area down with alcohol and let it cure for days.
Been there, done that, never again.
If you wear glasses they are a must (IMO)
I have been using them for years and love em.
I think I will pierce the nipple and hang a custom ring from it just for kicks.
when my nipple fell off i just took some good epoxy and glued it back on, never lost the nipple again.
Man you guy's seem to have alot of nipple problems! Whenever my nipple gives me trouble I just replace it!!:eek:
Other than that love the Quick Straps!!!
