Quick Straps!
B
BigTruck
ACCOUNT CLOSED
Anyone using these? I have used them for what seems like forever and I love them. Anyone a dealer or know where to get them as i am due for a couple new pairs.
Thanks.
Rob.
I sell quick straps by the hords, in stock blu, blk or red 4 your cost $15.75 each, brand new ready to go,
thnks
dan
jet chevrolet and rv
253-838-7600
ive used them for about 4 or 5 years now and i love them. i also use them for dirtbikin and sleddin, they're nice when your ridin and need to pull your goggles off cuz they fog or get dirty or somethin dont even need to stop one hand and they're off. most sled/bike shops sell them around here.
you should be able to buy them at any place that sells helmets....
at least up here in n.idaho that's how it is.
good luck...
if you get two pairs, make sure that you either 1. keep a helmet strap with you, or 2. keep the extra nipple one with you.....so that way you can have a strap or a spare just in case you break your nipple part off of your helmet...
sorry don't know what the side with the big plastic looking nipple part is called that fasten's to your helmet....i just like to to say nipple...
good luck...
Seems to me you like nipples???:eek:
Just a guess...
I see more riders with them than without. Around here you can get them pretty much at any dealership, when they're in stock. One item you can't seem to get much cheaper online.
Guess I'm the odd man out. I never did like them. Couldnt get them to seal up tight and didnt like the fact that it was a PITA to remove them from your helmet to thaw out or change to another pair. Eric
I had the same problem, took an exacto knife and enlarged the area that engages the so-called "nipple", comes loose much easier now. Makes changing goggles less of a PITA.
If you couldn't get them to seal up tight it's either the goggle fit, or you installed them to far forward, not the QS. I always shave the inside of the slot that goes over the nipple a tiny bit with my knife so they slide on and off without pulling the nipple off.
I like my Quick Straps, but my spare pair of goggles have the normal strap. This came in quite handy this past season when the "NIPPLE" broke off. Nobody likes a broken NIPPLE!!!
I think I'll take a drill and pierce the nipple,then I'll put a bar thru it so the straps can't fall off. :)
I have used them for 3 years. But what I hate, is when they fog, or you just want to pull them off for a but cause your hot. They dangle on the side, annoying when doing a lookback, and fill with snow. Im going to try the habervision fog Eliminator this year. Also, I wear glasses, so that was the reason for QS, I got the Habervision glasses inserts for the goggles. So i wont need my daily glasses. we'll see how that combo works for not fogging and being ablet o see
