P
polarisboyc
There is a bushing that the bolt that holds the ski on goes through, does that need to come out when i get them powder coated? I cant tell if its plastic or metal! Its on a 2013 pro.
How 'bout getting it anodized?
Aren't the spindles cast aluminum? My anodizer said cast doesn't Anodize well!
Sent from my DROID RAZR using Tapatalk now Free
The IQ's were cast or forged, the PRO's, Rush's, IQR's are an extruded heat treated alloy and if exposed to 300 degrees for any time at all it takes the heat treatment out and you loose about half of its strength depending on the specific alloy.
Yes, with Anodizing it is harder for them to get an exact color match (cast vs. extruded), as well as the surface is rougher so it doesn't look as consistent as an anodized extrusion. The alloying elements also can play he!! with the process as the zinc and other metals can negate how well it works.
You guys will do what you want regardless, I just see some responsibility in educating the uninformed on their decisions. Those decisions can have a very negative consequences to themselves, their families, and their riding partners, should a part fail because of it.
I by no means know it all, but I know enough that I will not Powder coat my aluminum. As I live in Alaska which at present has no anodizing facility and shipping is outrageous, if the parts are not pre-anodized when I receive them, they likely do not get coated at all.
Shippings not bad if you can fit them in a flat rate box lol..
And just for the record since there are so many people on here concerned about taking the temper out, can anyone actually PROVE that it takes the temper out? Or Loudhandle are you just talking out of your *** as you just recently accused someone of doing on another post?
