A
AK IQ Pilot
So, I spent the three day weekend riding with 6 new Pro's, we did a lot of QD belt testing measuring temperature and observed run out and various other things on these new sleds. This may get a little long but I wanted to share my onservations.
All sleds were 800, 155's.
All but one had the '13 drive axle with collar.
All sleds had stock muffler and were virtually stock engine wise.
No sled had any visable run out on the upper or lower pulley. Not measured by a dial indicator but none visable. I will measure my own sleds with a dial indicator ASAP.
I will discuss the three that I have the most data on.
Sled 1. Black non limited has a 2012 drive axle in it and had already sheared teeth on a QD belt in about 55 miles. This happened in powder when climbing and catching traction on wind blown base. Half the teeth sheared and the sled would no longer move. This sled got a new drive belt and it was broken in for 100 miles on flat river running with 6" of fresh snow. During break in the first belt left lots of black particles all over the belt drive area. If you have seen these particles you know what I mean. 2mm x 4mm pieces of thin black belt material. Mold Release material is what some are calling it. Second belt does not have any black particles coming off it and it has about 150 miles on it now.
Sled 2. White Spring order Limited. Broke in the belt with 100 miles of fast river riding with 6" of snow. Plenty of hard pulls on flat ground after the first 50 miles. No evidence of belt material anywhere around drive belt. Sled now has 255 miles of decent to hard riding. No heavy deep snow conditions and no steep hard climbing. Mostly boondocking and tree riding.
Sled 3, mine. White Spring Order Limited. Began the weekend with 5 miles on the odometer. Broke in belt gently with slow and easy trail riding for the first 40 miles. Moderate trail and tree riding the next 50 miles. A few WOT pulls after that. No evidence of belt material anywhere around the drive belt.
Belt temperatures. I checked the drive system and muffler temperatures dozens of times this weekend with a Snap On digital infrared temp gun. All sleds had basically the same belt and pully temps depending on how and where they were ridden just before the check.
Ambient temps were about 15f.
On moderate and slightly agressive trails the belt, pulley, rotor and muffler temps would be as follows.
Drive side of the belt woulld show 95-100 both inside and outside.
Coast side (next to the muffler) would show 100-105 inside and out
Upper pulley would show 125-130 at the hottest part of the pulley which was always on the inside flat under the teeth. The hub face and teeth were always colder by 5 degrees at least.
Lower Pulley would show 80-85 at the hottest part of the pulley.
Brake rotor would show 80-85 at the braking surface but hotter near the hub.
Muffler woulf be about 275 or so at the closest point ot the belt.
Moderate tree riding on relatively flat ground. 20" of dense but not heavy snow.
All across the board the temps were 10* hotter except the brake rotor and lower pulley. They always stayed between 80 & 85F. Muffler was hotter by 25 deg at least.
Moderate to hard pulls on relatively flat ground across 1/2 to 1 mile long swamps. 20" of dense but not heavy snow. 7200-8200 RPM. 45-55 MPH. I would still consider this a relatively light to moderate load for the drive system.
Belt, upper pulley and muffler temps went way up. Both sides of the drive belt reached 135+ at times. Upper pulley saw 155 to 160f. Muffler saw 350+ near the drive belt. Lower pulley and brake were still around 90f.
I have heard that the belt may begin to degrade at 185f. Not sure how accurate this is. I could easily see the drive belt approaching those kinds of temps under heavy loads. That doesn't explain why some sleds have sheared teeth under almost no load but I do think temperature could be a contributing factor with some of these failures.
I have a friend with a new Pro and a small muffler. He feels the drive belt is considerably cooler than the numbers I am posting now. I will try to do some side by side testing with a sled with an aftermarket muffler soon.
I can not explain why some belts throw lots of black particals off and some don't. The first belt on Sled 1 was filthy and sheered teeth in under 50 miles. The second belt is clean and now has 150 miles on it.
