The RKT turbo domes are probably really helping you out.
well then is it not telling you that you need some higher octane at lower elevation..??...or lower boost..??
Where are you in the koots when you come to youre senses ill show you how to get av gas in nelson
look..i even mix a tad of race in my bigbore (now I use Torco )because its on the edge...with 13.5 domes..haha..
Hey get something like that new piece ZBROS just came out with or the ovs one for your wheelie issue
http://www.snowest.com/forum/showthread.php?t=363779
enlarge your orifices on your current injectors..but more fuel flow won't help if you have not maxed out your duty cycle anyway would it..??
isn't the placement of the extra injector as important as the extra flow..??
Not sure exactly what the orifices are but I feel like I have an idea.. Im sure I'm close to being maxed out on my duty cycle and if I'm correct high flowing injectors would be similar to adding an extra injector but maybe not quite as effective? Am I right in thinking this? Because it is a much cheaper option if it does anything even similar to an extra injector.
Dude just do the injector in the charge tube. I wouldn't try reinventing the wheel. There is a reason they added it to the kits now. I wouldn't try to cheap skate out when running boost. You'll save yourself $100 but then melt down your motor and it will cost more in the end.
Im looking into it and will if I can. Its just tough since I'm a broke student making $11.25/h and right now I'm putting every penny into either gas for the sled or gas for the truck. Im just trying to make the most of what I have but obviously it needs to actually run and stay running for it to mean anything to me to ride. I understand 100% what your saying and I am working towards the extra injector if possible, it'll be a few pay checks though
