This is what I like to see, nice work! Got any more photos?
That really looks nice.
I have thought so much about a similar project. Yes, the headset becomes a significant stress point and you may be on the right track trying to go with A-arms. I really want a ride report, with the different front ski travel as you hit abrupt/steep snow surfaces, will the more straight up and down travel make the ski less likely to want to pop up and over stiff hits?
In my head if keeping a motorcycle style front, alot of changes could be made as there would never be a front tire. Spindle assembly could be much smaller as the entire suspension could be lowered. Headset could also be made significantly longer/taller to reduce the stress concentrations on it... but remember, I'm just thinking, I haven't built anything!
Hats off to you for putting this together. That's a ton of work and it really came out nice. Can't wait to see it on the snow and hear how it works.
How long and wide is the track? I agree the snowhawk style sled builds aren't for me but probably what the manufactures will give us some day.
Since you don't have a strut rod or a fork, Do you have a way to adjust fork height, ski pressure or rail tip pressure? It should be way less critical since your center of gravity is on the track.
How much turning radius can you get with the front end? I'm building a raptor 700 quad frame bike and might try the a-arms vs adding a fork might make the quad frame super heavy.
Very nice work.
A few things that I learned after 3 Timbersleds and 2 one off builds.
1: Shim the ski rubber so the front of carbide is 1/8” higher than the rear. (Tight rubber required)
2: Put the chain to the track-shaft inside the tunnel. (See #3 and 4)
3: Doing the direct drive like you did would allow you to eliminate the shaft extension by offsetting the motor very slightly left then building the gas tank to the right to balance it out.
4: Taper the top of the “tunnel” for smooth leg sweeps front to back.
5: Your “tunnel” could be UHMW plastic and hold much less snow. (Longer would keep snow off the helmet)
6: if at all possible run a track that is not spliced, that killed trackspeed on my sxf450 with a spliced 2.75x129 track.
Again, zero criticism here just wanting to pass my lessons learned on.
First, thanks a lot for taking the time to share all the testing you have done! Also thanks for all the build info that you posted on the forum, I have checked every of them and they are very inspiring!
1. that could be easy to do and I bet I make a good difference in the approach angle of the ski!
2. I have seen a few build this way and yes I think it will be a no brainer in the future! On this one if I have problem with the actual setup or the next one for sure! Like you said in 3 there is a lot of advantage that make the build simpler and more robust!
4. I have a small angle in the top sheet metal but notting very noticeable
5. True! there might be a snowflap mounted as a tunnel extension in the near future, this would prevent getting snow all over my back and act as a tunnel but give less restriction as an actual one since it will be able to bend if needed.
6. Well this splice is not my favourite choice but I didn't want to throw a 1000$ track to a project that I was not sure what it would end up like.... So the 20$ track plus few hour of work was a good deal... But this might as well get replaced for performance and reliability.
Again thanks a lot for your input and taking the time, as you know with your builds there is still a lot of question and a lot of work ahead!
12,5x120x2" (older timbersled) tracks can be found for super cheap and they work pretty good for 90% of the snow condition we get in Quebec. I ran those for a couple seasons until I found a good deal on a 12,5x120x2.5 track. This is all on my custom tedesled-like kits.
Now I am thinking seriously about trying the a-arm front end on my raptor build. Did you look into using a snowmobile spindle before you decided to make a custom one?
So is the bump steer eliminated by increasing castor as the front compresses? That can't even happen with a normal fork the castor reduces when the fork dives.
An Arctic Cat blast engine would be pretty amazing on this machine...........
The picture with weight shows a side panel in the background.
You must have done a few different iterations of design and fabrication.
Care to share any of your lessons learned? ?
Based off these two pictures and measurements taken from a proclimb chassis I’m estimating the width to be 16-17” at the widest.
Put that wide point in front of the footpegs and it’s just clearing a little snow in front of your leg.
Videos posted by adult AC riders in deep snow show the engine has good potential to power a snowbike quite quickly. (65 hp claimed)
Main gains i see are: EFI, 3 stage exhaust valve, engine reverse, cold weather tuned from factory and cvt holding the engine at or near peak power through a broad range of trackspeeds.
Sorry for the derail.
You should start a thread and post pictures of your builds.
Last pictures i find of yours were from 2015.
Did you make your own footpeg brackets to bolt to the side panels or was there some from a bike that could be purchased? Most the bike ones I've seen mount to the bike at a weird angle.
Also I can't get real excited about 65hp with a cvt. It won't perform any better than what we have power wise but the chassis in the AC pattent looks about right for proper handling. I enjoy shifting too much and if they offer a beginer friendly cvt bike all our secret riding spots will become tracked out real fast by rental snowbikers!
Looking at my 800 pro ....drop the recoil and you could really narrow and centralize the motor and cvt ...Grind the bumper inside the yamaha peg mounts until the peg sits level.
I used ktm pegs in yamaha mounts the same way.
The only gains from cvt will be at each shift. Manual transmission engine power output follows rpm.
Example from yz450f, Engage 1st gear at 30 hp rev up to 60 hp (1-10 mph trackpeed) shift back to 35 hp rev up to 60 hp (8-18 mph trackspeed) shift back to 35 hp rev up to 60 hp (16-27 mph trackspeed)
Example from ac blast engine: rev to 4000 rpm engage at 30 hp rev up to 65 hp hold at 65 hp as trackspeed raises through 5-10-20-25-30-35 mph........
Power to the snow gets you places.
It would be different for sure.........
Dodge a tree and the 1 second delay before downshift slows you down ( low hp output due to low rpm) , uphill switchback turn and downshift at the same time lose momentum, come over a rise and gain speed across a flat spot before hitting the steep, upshift, then downshift losing momentum at both shifts. (Moment in time with zero power transfer to the snow)
Reading some Data logs of streetbike races is a great way to see the time spent between shifts with zero acceleration.
In comparison asphalt friction to a tire compared to snow dragging down trackspeed.
The lack of acceleration seems more important. (Or deceleration in the case of snowbikes)
For me mistakes made with a manual transmission snowbike kill the fun factor (1-1.5 second delays in power delivery not letting me keep momentum and get above the tree or over the ridge), tight trees and steep canyons are my favorite terrain.
I find myself body English riding the snowbike when the going gets tough, this leaves me not in position to make optimal shift movement.
The R6 and ninja 636 bikes both went great in wide open spaces, the yz450f and sxf450 both went well in shallow snow and my turbo axys rmk goes great everywhere i can crush trees and dodge them.
I want the best of all 3 worlds......
