Pump Gas Turbo Question
The 901 rocked at Fairview on huge boost. It is also very dependable, makes good torque on the bottom end, and I think it will prove to be an awesome upgrade to a pump-gas turbo M8. One more way to squeak out more power from the fuel you get at the pump with out compromising durability.
Thanks Junior
On your setup the turbo doesn't smoke when the sled rolls over?
what ever oil that is in the turbo its self and what is getting pumped witch is very little will make it smoke but our oil tank is baffeled so the oil dose not just run right through the turbo like old tanks I have had.
Thanks Junior
That thing at 20+lbs of boost was haulin the mail!!!
Wasnt the performer at low boost though compared to the standard 8 IMO.
J Kinzer is right the tank will be new and you will never have any smoke at all making it unlike any tank on the turbo market also looks even better. Install is even easier now only taking a few min to install the whole oil system. Incorporated into the tank is a oil check system that will let you check your oil with just a glance.
So can they retro this to an exsisting tank or is a new tank the only fix?
