This is a Polaris based case with PSI crank, Dial a Dome Heads and Ceramic coated twin pipes. This will fit Cat because I have custom mounts and it is currently installed in a Mountain Cat. The new price $2300 or $2700 with 46mm big air carbs
wondering if you still have this engine. i have a rmk wedge that i want to put something new in and i think this motor is it. do you still have the plate for it?
The carbs are 46mm big air check out PSI website for more info. I do not know the series I had a pair of 42mm on a 890 that had the power jets update this is already done to these carbs(series 2) The needles that are in the carbs are for running the 1085 at elevation 8000- up I will see if I can get you those numbers, I am sure they are printed on the needles? I am looking to sell the motor first (with 1st option on carbs going with motor because they are already set up for the motor.......I will try to get more info from white litening on the carbs and motor......
