If you know what your doing go big, otherwise its easier to go with a kit, I wouldn't use any kit running anything less than a 2871.
I want to ride skidooits creations
2871 would be a great choice for your 800, it come stock in many 800 turbo kits, I donno why tss thinks its HUGE.
jackson is rider. any of the turbos i mentioned would get them over just as fast, just depends whos piloting. the tapio crew could put a kitty kat over the top faster then most people.
hell, we also ran that sled with a 66 aero, slowest spooling laziest of them all. but very abrupt when it comes on so feels like it hits hard and makes power.
The newer gtx series out flow the old 2860 and 2871
--don't forget, you may also need a rear suspension
How many times do they have to say the bigger turbo improves throttle response?
The bigger exhaust turbine gives the exhaust more leverage to spool quicker with less effort!!!
I have worked with a buddy and we did a poo 800 motor in a tube chassis and did the following combos and it only got better every time we changed.
2871 .86 exhaust housing. 7-8#... ran really good, consistant, smooth power.
3071-wg-.64 exhaust housing (this is the internally gated 3071, with not fullsize exhaust wheel) worked even better, pulled same clutching at 4-5# of boost. and more linear out of hole all the way to full throttle, felt less turbod and more like a BIG bore.
fullsize 3071, Tial .64 exhaust housing, external wastegate and 3" mandrel charge tube that y'd into the motor. pulled same clutchign at 3.3# of boost. Even smoother, more linear, and unreal power on the top for low boost.
To give you an idea, We just built a nytro, 3071 external gate .64 housing, running 11.5# of boost and snapped a rod with no deto. the rods are good to ~270 horse. stock motor is 130 horse. you do the math, instant response, and STUPID power on the top end. fastest sled i have ever ridden hands down.
Sounds like we want the same think.
I only ride trees and short open hills. I have never had WOT more then max 10 seconds. Usually max 5 seconds.
So maine priority for me is best setup for that type of riding
