new numbers where on 50\50 100 ll and 91 non eth at 6000 up.
double check your exhaust springs ,make sure that their the titatium super whammy springs. and not shinny carbon steel springs.
raised 6700 66 and 99 to take care of throttle modulation to keep it from going lean when backing out of throttle and getting back into it . and raised 8200 99 to add fuel for long hard pulls to keep from leaning when heat soaking . and none of this helped belt life haha
have you ran these numbers yet ,my guess is the midrange is going to be toasty hot be carefull lol
BELT LIFE HAHAHA. Have you found a fix for that
going to put the mtn valley set up to the test.won't be able to try it for atleast 3 weeks so I hope theres snow when I get back.
Kcdavidak I ran your numbers all weekend. I added even more fuel to the top end. I like the way it runs with your numbers. I do find it still gets really hot Egt's. do you think this is from hot charge temps? whats the solution?
What are the max charge temps shown on your box? Mine with the intercooler are usually showing a max of around 125-130. Highest I've seen is 153. A friend has a cutler without I/C and we have seen his temps over 200 multiple times.
Also running 50/50 100ll/91. Between 3000 to 5000 feet
how much boost are you running
