I think you are correct EZryder, our pump gas is two octanes away from beeing 100ll, and am going to grind away some metal, so the air box wont hit the bulkhead, then try out you fuel controller settings.
Ill give feedback on how it goes.
Thank you, and merry christmas to all of my fellow turboers out there!
Maybe thats something to look at. From what iver heard from others here, 14.5 should be safe at cruising, but maybe your right.
I would leave everything and raise your yellow up for more fuel on quick throttle movements. When you stab it wot from a dead stop how is its performance?
New problem/situation guys!
Driving normal at cruising A/F ratio at 13.5 to 15 and then give it WOT, runs good at WOT with an A/F ratio at around 12 for 1-2sec but suddenly boggs out and started to only go on one cylinder. Checked the plugs and they were too bright in my opinion and both dry. Changed plug on PTO side after I found out that was dead. Started it, tried to ride and it ran great. Later in the night, same thing happens but now i only had to stop it, then start it again and were good to go. Hasnt happened since. Any toughts on what happend?
When my red/blue is too low or red is too high, I have encountered this. I run my single red around 1-2 and red/blue at 7ish. Just a tad to rich on this circuit makes my sled do the same thing.
