Pro to Khaos? Love the purple but want the Khaos
Barcode
SnoWest Sponsor
659
289
Hey. Anyone know the actual parts that make the Khaos the Khaos from the Pro? Is it just the rails? I really like the RMK purple. Wondering if its with swiping some easy parts to get the Khaos with the RMK colours.
Thansk
Allan
Scott
Scott Stiegler
69,618
11,737
W Mont
We have a full package utilizing fox shocks, save the roughly 1k, snowcheck rmk, convert to khaos using our rails, fox shocks and have an overall way nicer suspension package when your done!
That sounds awesome.
What's the package cost?
Will you coat the rails before they ship out?
madmax
3,151
Salt lake city
Which fox shocks are they? The Khaos shocks are pretty nice.
If you price out an identical 2021 850, qd2 155 axys vs Khaos (all black) the difference is $700. Ice age rails $500ish, a set of four shocks as good as the khaos shocks $1800, better shocks $3000 or more. Very few guys will utilize the Khaos shocks, let alone need anything better. If you can’t do the work yourself you’ll pay a dealer at least $200 in labor. Ive looked into this a lot cuz I want a purple and white khaos, it’ll cost you at least $1,500 more to buy a RMK axys and try to make a Khaos out of it.
edgey
1,050
557
Check out raptors site this is what I'm going to do to the wife's sled she likes the 160ish track length sleds but she says the front end feels a little heavier than a 155 so I'm going to put the raptor kit on her purple 165 to give her kind of in between pro & khaos sled.
IceAge Performance
779
93
Gallatin Gateway, MT
The package which we sold for this winter and will also be available rolling into next year is the Float 3 QS3-R Burandt edition shocks.
While the WER Velocity shocks are by far the best shock package Polaris has offered on a sled it is still unfortunately rather "dumbed down" in setup for consumers. We put a couple hundred miles on the factory shocks to get comfortable with various configs before switching and running the new fox package as well as did side by side back to back laps on harsh terrain to really compare what was different.
The simples change but biggest gain we saw with the Fox package was ease of adjustment, on the Velocity shocks, too many finite clicks exceeded what any of our test riders cared to tinker with and it was very common to lose track of where you were at on adjustments. This resulted in guys just sort of just cranking knobs without much purpose. The Fox with the QS3 package is awesome and an easy way to make a substantial change from 1-2 or 2-3 etc and also very quick easy visual to see what position you are in. The 3 position clickers represent distinct changes in shock performance that anyone could feel, not some minute change that is almost impossible to discern.
Range of use - The next thing would be the broad range a single setup would run, meaning, with one setup (and clicker position/air pressures) we could easily ride in a larger variety of terrain without making adjustments to the shocks. The progressive nature of air springs coupled with the Evol chamber creates an impressive ramp up in spring rate. This means you have a nice soft initial rate ramping up to very firm right at bottom out. We found various members of our team could run the same setup from trail to powder/backcountry riding to rather large jumps all running the same setup. With the stock velocity shock we just found we were making adjustments more often chasing the "perfect" feel.
GoBigParts
4,078
917
Michigan
www.gobigparts.com
kylant
1,672
396
83
CA
Unfortunately yes, the Khaos shocks from fox were available in limited quantity for this year and they are all sold out. We will have a snowcheck option for sull packages available shortly.
hopefully you have a cheaper shock option as well. some of us do not need/want $3k shocks
