W
wintertoyz
New member
Are there a lot of differences between these two besides a chain case and QD? And how does the assault climb vs the pro? Thinking assault because of all the ditch bangin here in Mn Thanks
My thoughts...
Go with the slightly more maneuverable 40" stance of the Standard-RMK ... and get the benefits of the extra cooler (it makes up for it's own weight in lower ice buildup at the front of the tunnel)
The price difference is $1100 and you will find dealers willing to give great deals on the Standards during snowcheck.
My 2 cents.
For that, you buy some top notch aftermarket shocks.... you will have a more heavy -duty rear bumper and overstructure to boot... and bogies that you can choose to use...or not. Same 5.1 series track as the PRO and Assault with the powder option.
Same strength of A-arm as the Assault and a chaincase for no problems or worries with the belt drive.
The climbing between the two is comparable then??
So the only real difference between the Assault and STD is the shocks and the cooler, Right? So if you buy the STD and then have to switch out the Shocks,(and I would) other then having the cooler on the STD, are you not going to be close to the same amount of money? So why not just get the Assault?( If the cooler is not that big of a factor to you), Or am I missing something?
Will not the Assault with the 5.1 track preform as well as the PRO in deep snow?
For those that have the 13 Assault, is their that much difference in the PRO belt QD over having the chain case on the Assault ?
