Y
yotaman1290
So i was on the fence about what pistons to do like I'm sure a lot of you. I went with the RKT Direct Replacement pistons and here is what i got to say. Ordered them and 2 days later they showed up! They looked great! Got my old pistons out and did a little measuring. The piston to cyl clearance on the OEM pistons was .01" which is way out of spec. Supposed to be .005-.006". And yes they rocked like crazy in the cylinder i was amazed! The new pistons were a perfect fit at .005" and the ring end gap was also perfect right at .018". I didn't have to file them at all.
Got to fire it up a few minutes ago and she started 2nd pull. I was surprised because i replaced the fuel filter as well and thought it would take a little more. Anyway it runs a lot smoother at idle. Going to go break it in this weekend ill report back.
***UPDATE***
Rode it today made it 10 miles up the trail and pto side lost compression. It was using oil and I premixed fuel at 150:1 sled never went above 150 degrees and ran amazing till it lost compression. I'm confused now!! Going to tear into it and I'll report back
UPDATE
Tore it down to find a messed up cylinder, piston and head. It was severely scarred and mashed up. The only thing i can think of is when i was tearing it down one of the tabs broke and flew off the small coolant hose on the head and i couldn't find it. I believe it landed in my air box and sucked into the motor.
Heres some picures of the damage. The last picture is of the pieces of the clamp that was stuck in the top of the piston!!
***UPDATE***
UPDATE
