PRO RMK GAS RACK?
Anything that fits the dragon/IQ chassis will bolt right onto the pro tunnel..tons of choices out there..
I would think eric(mountain horse) will chime in here..he normally has all the trick stuff figured out...
I'm using my holz rack off my IQ Raw chassis. The Pro's have a raised portion down the center of the tunnel for wiring. The new 2011 holz rack has a section removed so it sits flush with tunnel. I used my old rack and used rubber spacers to allow the rack to sit above the raised portion. The holz rack is simple, well built and looks good.
Kale
I am using a tank and rack system off my summit xp. I like the tank becouse it is 3.2 gallons, and it doesn't stick up to far for leg transition. The heat exchangers are different so I just fabricated a little "lift kit" out of some old hi-fax ends. Also I made it removable for those days you dont want anything back there.
I like the craigerbuilt can and bag setup but my can has "sucked" itself in. I haven't figured out how to get it to pop back out.
For holding just a can Polaris makes a good looking and functional accessory one. My only complaint with it is that the crossbars are not threaded and it comes with self-tapping screws for them. You're sure to bugger up the bar trying to hold it with a box-end wrench while you screw in the screws because the bar only has a flat on one side. Stupid. Either machine two flats into the bar or thread the f'n thing at the factory.
Rob
X2 on the Mountain Addictions setup. When you don't need the cans, slide them off and slide the bag on. Lots of storage and can options.
got a skidoo on one, and some other brand on another.
skidoo
attachment.php
crappy pick but some other brand i bought for the other pro
attachment.php
X3 mountain addiction, great people to work with also....I went with 2) 1.3 gallon tanks and the large storage box, you can put both on or either/or depending on the ride that day.
Based on tunnel bending trouble with it might be a good idea to get a tunnel support style gas rack..
$249.00 natural aluminum.
Custom designs also available.
