Did they change anything about this shaft? Seems like alot of failures compared to past years when the P-85 has been Mr reliable. Are they still mfgd by TEAM?
I know that on my pro when I got it home and went to pull the clutch off before I rode it I couldn't believe how easy it came off. I've pulled a lot of clutches off and this one couldn't have been torqued more than 15 lbs from the factory.
yep it's warrantied
How about the rest of the motor?
I would think that something like this breaking at 6000+ rpm ain't going to be good for the crank. Won't ever be the same anyway.
Here are some pics before I welded and pulled off!
My 800 Rush clutch mounting bolt had less then 40 ft/lbs, at 2 miles.I think some dealers just push the sled out door without checking any thing, when I got mine home the first thing I did was check the clutch maybe had 40lbs at the most, track took 4 full turns to even get close, chain case 3 full turns, and two full turns on the steering so the bars would be straight. I have been riding for close to 30 years and every sled I have bought I have had to do something that should have been done during the dealer set up.
