The taper needs to be a clean, dry metal to metal fit. Anything else and you are asking for more trouble.
Note: Anti-Seize is essentially a grease with metal particles in it such as zinc. It will inhibit the metal to metal contact required to take the load, and it also will inhibit the alignment, you would essentially be putting grit in between the two mating faces and destroying both of them in the process. DO NOT PUT ANYTHING ON THE TAPER SURFACES, assembled clean and dry and the correct torque and re-torque after heat cycling are the key.
There is a proper clutch holding tool but I have misplaced mine so I use a pry bar through the towers of the clutch.
Lol, its not like I am beating on it with the bar. It's to prevent turning, torquing the bolt is a smooth action. Smooth and constant tension.That makes me cringe!! I use a large strap wrench I made to distribute the holding pressure around the clutch evenly.
I wouldnt recommend a bar to the average person either. I forget that not everyone has common sense.
