Pre-season DS Titanium Exhaust Can
No it has three, two that attach the can to the expansion chamber and one on the back side that attaches from the can to the bulkhead area and holds the can in place. It feels pretty solid.
Mine has a spring tab on the back side as well. I attached a spring from it to the bulkhead area where the oem muffler spring attached.
Yours was a early build correct? Maybe he forgot the tab on mine are doesnt feel it needed. It's pretty solid with the set up I have now.
It probably was an early build, I'm not sure. From your picture I think it might be a good idea to run an additional spring from the front of your can down to the oem front muffler attachment. From the same tab, one spring goes to the expansion chamber and the other goes down to the front lower mounting location.
The angle of the flange is slightly off, but it doesn't go right through it.
Mine butts up right to it. The u shaped bracket on the side holds it from trying to go too for through the bottom of the pan.
