I did try, and it made a HUGE difference. All I can say is DO IT! You will have to get the clutching fixed after they are blocked, or else you will start experience DET by over rev.
So your saying the sled made more power with them blocked? Cuz u were over revving? So you added some weight?
From my understanding the valves are fully open at full throttle anyways, so I can't see where more power is coming from? ( atleast this is how it was on my 10 800..
X2 on more info! How many rpms did you pick up blocking them?
Cheers
Well that's not the point, they open SOONER so you get power quicker and that actually can lead to retaining more track speed and may need to add more weight to clutches. Haven't done it to the Pro but certainly works for the 800R and there's no downside other than losing some fuel mileage.
Have FUN!
G MAN
alright alright i'll try it tonight and run it tomarrow
thats the plan.![]()
However, (and I would caution this), at the time the valves open, the engine actually suffers a momentary DROP in airflow, then a steady increase in airflow. While the ECU is controlling the solenoid which in turn controls when the valves open, the ECU also matches the drop in airflow with a reduction in fuel delivered to the cylinders. IF you take away the ECU's ability to control the valves (by blocking the lines) then you also run the risk of a momentary lean condition when the ECU signals the valves to open and cuts fuel...if the valves are already open, you'll have increased airflow with a drop in fuel delivery....lean condition!!
It worked on the earlier VES models that were carb'd because the carbs handled the fuel delivery in an "on demand" manner....the problems with EFI in this case (because this is not a closed loop EFI system) the computer only does what it's told to do (fuel curve) and is oblivious to actual "demand".....
