I was just making the point because we tend to compare things with what most people will run not what's approved.Yes, but that's standard for just about any acceptance testing for any internal combustion engine since the 1970's. Remember when they started sealing off jet adjustments in carburetors.......
Where I ride ,the rated, approved, and waranteed sled, the pro is 3.28 lbs or hp and the turbo Yami is 3.38 lbs per hp.
Sure you can turn the Yami up but then it's not covered by factory warantee or EPA tested and we are no longer comparing apples to apples(ish...it's still a $13k sled with a $2k upgrade compared to an $11k sled bone stock)
Also for some reason we keep comparing the lightest 2 stroke to the lightest 4 stroke, not the comparable 2 stroke. IMO we need to be looking at its 2 stroke brother for direct apples to apples comparison. The m8 is the same sled without the 4 stroke "heavy" heart. It weighs in at 569 lbs ready to ride and makes right at 160 hp. That is 3.56 lbs per hp(2013 HCR 153" - sorry I don't have ready to ride weights of a '15 162" M8000, but should be close enough for the point I'm getting to)
That tells us we are there with 4 stroke technology. Sure it can always get lighter and better, but you could put the motor in a lighter chassis (ie pro) and knock another 50-60 lbs off of the sled, but power to weight, chassis for chassis, comparing motor packages, ready to ride the 4 stroke is better.
CatRpillar- I don't remember those days...I was born in '89 and have days I wish the EPA wouldn't have ever been created. I feel they go to far (pretty much everything they mandate on the exhaust side ie DPF and CAT's), but also they are the reason we have the cool technology we do today such as direct injection (well fuel injection actually) and lightweight 4 strokes. Get the good with the bad and make the best of it I guess.
