Power Commander ????? for IQ
I
IDAHO HOT SHOT
I'm programming my 09 800 with a pc5 using the manual map. Do i need to put a + in front of my numbers to get more fuel or just the number itself? Thanks for the help.
I'm thinking I'm in that 5 range, which means i need to get the sled/ engine to a good running temperature before I start looking at the plugs. Correct?
I did not let the sled run to long before I started dinking around with it tonight. So if cold is referring to engine temp then I probably need to get this thing out on the hill to do honest testing
When they say cold, they are referring to the heat range of the plug. We can ignore that. To properly read plugs you need to run the sled at the specific rpm range that you want to read. I'd run an 1/8 of a mile at that rpm and hit the kill switch, then read.
I'm gonna take'er out this weekend and do some seat of my pants tests. It will probably be better to test under load anyway. Thanks for your time and knowledge.
