T
TTE
First of make 100% sure you have a 0.035" orfice in the oil feed line to the turbo.
Easy way to check if oil return pump is doing is job:
- pull the oil return hose underneath the turbo
- attach a rubber hose with same ID to oil drain on the turbo
- run both hoses to a clear bottle
- fill the bottle up with a little motor oil - same as engine is using
- fire up the baby
- rev the engine
- if pump is working correct the pump should be able to drain the bottle - both at idle and with higher rpm
If it's not working - make sure that there is no debrise in the pump, or return lines and that the ground wire on the oil pump secured really good.
I don't know how the PL return pump is wired. But on the bender RX-1 turbo kit I wired the oil return pump so I could run the return pump on the KEY without starting the engine. That way I could take out any oil pressure in the oil feedline after engine is shut off. May be the oil catch can under the turbo isn't big enough to drain the pressure in the feedline after engine is shut off? If so oil wil find the easiest way - could that be past you seals over time?
- fire up the baby
- rev the engine
