***Poo primary on a Doo questions***
ragincajun
ok. here is the deal. i picked up a polaris primary and i am going to have the taper machined to fit my pto end on my doo REV. i was just wondering if i can use my doo belts and has anyone had probs with the clutch hitting your side pannel.
yes yopu can use your stock belt, no it wont hit the side panel. It is very imporant that you dont just go to any machine shop to have the taper cut. i suggest Dave Jaffe in Bozeman Montana, he did mine and he has done a bunch before.
slight highjack. Thanks for the info. I am in the process of putting a modded 800 rev motor in a IQR and I was wondering who around could machine the clutch for me.
I would have it done my Micro-Belmont, some machinists MAY be able to do a good job, but having someone who KNOWS what it takes to do it correctly may save you alot of $$ and problems in the long run.
thanks for the help guys. they guy who is doing the machining has been a machinist for almost 30 years and had a high perf. head/ motor shop for 20yrs so he knows his **** otherwise i would be a little sceptical about doing this. i will have it balanced after i get it machined. thanks for the info!
